Exporting units?!
Tru7hTru7h Member Posts: 20 ✭✭
Hi Onshape Community,
I'm having an issue with OnShape. I'll export a Part Studio and it will change the units, and therefore the size of the part on me. For just one instance, I'm working with a fairly simple part that's essentially a 3" diameter disc (linked below). When I export (I'm using .stl and .step) it comes out as a 3mm diameter part! That's how the file is read by Meshmixer, Shapeways.com, thingverse, and several other systems. It's not me, and I'm not crazy, but I might be getting there! Please help!
https://cad.onshape.com/documents/d16d0e5c2db2afdedfe61329/w/06f3721b775a713eac8d9606/e/b68aaa8647f6b60b37991990
    @Tru7h
    Try exporting it with units set to mm
    IR for AS/NZS 1100
  • Tru7hTru7h Member Posts: 20 ✭✭
    Yes, I've done that. Sorry I forgot to include mention of trying that approach.
    @Tru7h
    Does changing the workspace units to mm fix it?
    IR for AS/NZS 1100
  • robert_morrisrobert_morris OS Professional, Developers Posts: 172 PRO
    STL files do not actually export what the units are for the part. It only says that the part is 3 "somethings" in diameter.
    So if you export the piece as a 3in. diameter part, but the other software is set to mm, then it will come in as a 3mm diameter part. You have to make sure that the import/export units settings are the same for both software.
