Create drawing with dimensions in feet only (no inches)
spencer_russell015
Member Posts: 2 ✭
in Drawings
I'm using OnShape to calculate distances and add dimensions to a map. I imported the image and used the scale at the bottom to set the dimensions, and then started measuring. Then I created a drawing from the sketch. (I also needed to import the image separately because for some reason the image in the sketch didn't get transferred to the drawing).
Is there a way to get the drawing to display just feet with no inches? The inches aren't meaningful here and they just clutter up the drawing.
This is what I have so far:
