FLAT BOTTOM HOLE THREADS
in General
Can I make full threads in a flat bottom hole within one wrap of the bottom with the hole command? I keep having problems with the drill point. I need to keep the threads almost to the bottom and use the flat bottom for a seal.Yes, I can construct it with the helix command but i would like to use the hole command if possible.
