Merge available?
adam_76
Member Posts: 3 ✭
I'm trying to branch and merge simple shapes. I don't even see a Merge button in my Versions view. From the documentation, it should be right there next to the Save Version button, but I don't see it. Has this feature been removed? Thanks!
@adam_76 @jakeramsley answer is correct. You will NOT see a merge option on the same workspace you are on. If you select a workspace to pull changes into your current workspace you will see the option. This is one thing that can be confusing to new users of Merge. MERGE = PULL
With that being said, you are selecting a workspace or version from the graph to pull changes into your current space. Just remember, everything in every tab merges. We will work on making this selective and have more tools to assist on making decisions on merge in the future. Hope that clears things up for you.Lou Gallo
Sr. Director of Product Definition. UX and Support5
Merge is located under the gear menu of a version/workspace that isn't part of the same tree.
We will update the documentation around this.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com1 -
This just doesn't appear for me. Please see attached image.0
Sr. Director of Product Definition. UX and Support5 -
Got it. Sorry for my confusion! Thanks for your help.0
I made a mistake and pulled the main into branch . reverse in history doesn't make any difference I am lost?0
There should be a history entry on the branch that had main pulled into it that says something like 'Merge from Main'. If you select the entry just before it and chose 'Restore', the merge effectively isn't applied. If there is an issue with this, please use the '?' option in your document and open a ticket with support.svenolov_nystrom said:I made a mistake and pulled the main into branch . reverse in history doesn't make any difference I am lost?
