How do you make plain/printed text on a surface (no extrusion)?
gprosser
Member Posts: 2 ✭
I have sketched text on a surface and just want it to appear as printed black text on a surface without any extrusion or other feature. How can I best go about this?
1
Split faceSenior Director, Technical Services, EMEA0
I sure am missing something....I do not see OP plain "printed black text" on text example....I can not find a "split face" button as an option for the Text routine in the sketch routine1
Have you tried using Decal?0
I have tried decal.....does not transfer to a drawing or at least I was not able to get the decal on a drawing.....best option I have found is a note positioned on a drawing for example keeping track of what flat pattern is for what part when printing flat patterns to be used to build parts....it is also much easier to make a note rather than a decal.jtedeschi said:Have you tried using Decal?0 -
is your custom feature what Neil is talking about?MichaelPascoe said:
@don_b the example I gave is for a custom feature, not the native sketcher text feature. In the custom feature, there is an option for splitting the face instead of create new or add.0 -
found it.....thank you .....
never thought putting text on a part would be so interesting0 -
How is the custom feature called?
So I can look for it and add it.
I still can't do this. I had written the text as a sketch on the face I need the print to be shown. When I set an extrusion either surface o solid, as a new part or add, with depth 0 mm it results in an error.
@marianela_garcia here is the Text feature I mentioned. However there are other good ones across the forum if you search "text custom feature".
▚▞▚▞▚▞▚▞▚1 -
@MichaelPascoe Great! Thank you very much :)
