How do you make plain/printed text on a surface (no extrusion)?
gprosser
gprosser Member Posts: 2 ✭
I have sketched text on a surface and just want it to appear as printed black text on a surface without any extrusion or other feature. How can I best go about this?
    Split face
  • MichaelPascoe
    Here's a custom feature, Text, that has the "Split face" option directly within the text feature.
  • don_b
    don_b Member Posts: 169 ✭✭
    I sure am missing something....I do not see OP plain "printed black text" on text example....I can not find a "split face" button as an option for the Text routine in the sketch routine
  • jtedeschi
    jtedeschi Member Posts: 2 PRO
    Have you tried using Decal?
  • MichaelPascoe
    @don_b the example I gave is for a custom feature, not the native sketcher text feature. In the custom feature, there is an option for splitting the face instead of create new or add.
  • don_b
    I have tried decal.....does not transfer to a drawing or at least I was not able to get the decal on a drawing.....best option I have found is a note positioned on a drawing for example keeping track of what flat pattern is for what part when printing flat patterns to be used to build parts....it is also much easier to make a note rather than a decal.
  • don_b
    is your custom feature what Neil is talking about?
    S1mon Member Posts: 4,636 PRO
    Decals will show up on drawings if you use a shaded view. Depending on your needs, it may be helpful or not.
  • MichaelPascoe
    edited February 2024
    @don_b
    He's talking about the technique of splitting the face of your part using a sketch containing text. Which my feature does automatically. But no, he was not talking about my feature.
  • don_b
    found it.....thank you .....
    never thought putting text on a part would be so interesting
  • marianela
    marianela Member Posts: 23 ✭✭
    How is the custom feature called?
    So I can look for it and add it.
  • marianela
    I still can't do this. I had written the text as a sketch on the face I need the print to be shown. When I set an extrusion either surface o solid, as a new part or add, with depth 0 mm it results in an error.
  • MichaelPascoe
    @marianela_garcia here is the Text feature I mentioned. However there are other good ones across the forum if you search "text custom feature".
  • marianela
    @MichaelPascoe Great! Thank you very much :)
