How do you make plain/printed text on a surface (no extrusion)?
gprossergprosser Member Posts: 2
I have sketched text on a surface and just want it to appear as printed black text on a surface without any extrusion or other feature. How can I best go about this?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 6,023 image
    Split face
  • MichaelPascoeMichaelPascoe Member Posts: 2,844 PRO
    Here's a custom feature, Text, that has the "Split face" option directly within the text feature.
    RENDERCAD
  • don_bdon_b Member Posts: 152 ✭✭
    I sure am missing something....I do not see OP plain "printed black text" on text example....I can not find a "split face" button as an option for the Text routine in the sketch routine
  • jtedeschijtedeschi Member Posts: 2 PRO
    Have you tried using Decal?
    @don_b the example I gave is for a custom feature, not the native sketcher text feature. In the custom feature, there is an option for splitting the face instead of create new or add.
    RENDERCAD
    I have tried decal.....does not transfer to a drawing or at least I was not able to get the decal on a drawing.....best option I have found is a note positioned on a drawing for example keeping track of what flat pattern is for what part when printing flat patterns to be used to build parts....it is also much easier to make a note rather than a decal.
    is your custom feature what Neil is talking about?
  • S1monS1mon Member Posts: 4,194 PRO
    Decals will show up on drawings if you use a shaded view. Depending on your needs, it may be helpful or not.
    edited February 2024
    @don_b
    He's talking about the technique of splitting the face of your part using a sketch containing text. Which my feature does automatically. But no, he was not talking about my feature.
    RENDERCAD
    found it.....thank you .....
    never thought putting text on a part would be so interesting
