Change orientation of 3D scanned import
steven_armstrong
Member Posts: 13 ✭✭
Hi,
I have imported a mesh. It is of a motorcycle cylinder head. The scan is skewed. I have created three perpendicular planes that bisect the part accurately. Now I need to translate and rotate the part to line up with the system axis. All suggestions appreciated.
glen_dewsbury
Member Posts: 1,279 PRO
No. You may well generate other parts but initially not needed.steven_armstrong said:
So I must make a second part, correctly oriented and mate to that?S1mon said:No. In a part studio. https://cad.onshape.com/help/Content/transform.htm#MateD
You'll need 2 mate connecters to transform by mate connecters.
In provided example, drag the roll bar up and down to see the result of transform.
https://cad.onshape.com/documents/174eb7988c8cf61d5d226c4e/w/fd539f6558863d1fdb96a671/e/51ee80a84c0e47588e6626e2
