How can I get rid of the cut outs in the sheet metal module
I have been using the sheet metal module a few times and every time I get cut outs - indicated by the arrows - that form automatically. I don't know where to adjust settings to get rid of them.
dirk_van_der_vaart Member Posts: 554 ✭✭✭
Check your bent radius and have a look at this
https://cad.onshape.com/help/Content/sheetmetalbendrelief.htm
You can define the bend relief in the initial sheet metal model (see my screenshot) or adjust them individually as mentioned by dirk_van_der_vaart.
Hope this helps.
