How to design to center of gravity?
mike_phillips329
Member Posts: 3 ✭
in General
I'm new to Onshape but have over two decades of design work on other CAD systems like Creo Parametric. How can I create a mate, plane or some other "feature" at the center of gravity of my assembly. I'm sure Onshape has this capability as all other systems I've used can easily do this.
Here is a custom feature that will place a mate connector and a point at the center of gravity: Center of Gravity - Custom Feature
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
@martin_kopplow, yep, that would be an issue. Too bad we don't have custom features for assemblies. The best way I can imagine doing this with the current tools would be to edit part of the assembly in context, use the CG tool, then you will have the updated center of mass with a mate connector. Anytime you need to change the assembly, click the update context button again to update. This is a pretty limited workflow though.
@martin_kopplow
If you are going as complex as a helicopter, Find solution by @Konst_Sh may be of use to you. If you bring all your parts in context to a part studio, get the center of mass, then rotate what you need using variables to drive the movement, you could find the center of all of the center of masses for every combination of movement from the driving variables.
