How to create a surface based on the contour of an existing part
ode_tujoyode_tujoy Member Posts: 14
I want to create a bracket for a home security camera. Camera is more or less a cube but its sides are contoured and edges radiused. The radius is easy enough to figure out but I'm trying to match the contour of the camera body on all four sides. The bracket will be more or less a sleeve but with a relief cut front to back on the bottom side.
I could easily sketch a square, then shell it but I'd really like to match the contour.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 638 ✭✭✭
    Are the sides along the length of the camera flat or curved? - Scotty
  • ode_tujoyode_tujoy Member Posts: 14
    curved.
  • martin_kopplowmartin_kopplow Member Posts: 990 PRO
    Measuring with a caliper has worked wonders for me. Also stratecgcally arranged photos, taken with a looooong focus lens, can be very helpful when reproducing curved shapes. Place in the sketches and trace over them.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,019 PRO
    Take a guess and make a 2D drawing at full scale. Print it out, then cut with scissors and hold it against your camera. Adjust and repeat until close. Then switch to 3d printing.
    That camera is also curved from front to back, which may be harder to match.
    Consumer shapes like these are often modeled completely with surfacing tools to give them a premium appearance.
