What do I do when I want to Import a file into OnShape
I want to 3D print FIRST robotics earrings, but i don't know what to rename the file type i tried zip, stl, and ACIS, i want to import this file onto a document with all parts combined.
  • john_rousseaujohn_rousseau Member, Onshape Employees, Developers Posts: 410
    Hi Jessica. What type of file do you have that contains the earring design? Changing the extension on the file doesn't change what's in it, so it's important to leave the extension to reflect the format of the data.
    Our course on Importing and Exporting Data should have some good tips too: https://learn.onshape.com/courses/fundamentals-importing-and-exporting-data
