How can I use FeatureScript to get the longest edge of a part as a computed property
elias_bonauerelias_bonauer Member Posts: 4 ✭✭
I try to create a feature script that lets me get the longest edge of a part as a computed property in a user defined table.
So far I had no success other than get the compuedVolume as shown in an example somewhere.
Can yomebody give me a hint or an example how to get all edges, find the logest and rturn that as a computed propery?
Any help is highly appreciated!
  • elias_bonauerelias_bonauer Member Posts: 4 ✭✭
    Ok, i figured it out, I needed to use evaluateQuery and then return the value at index 0
    annotation { "Property Function Name" : "longestEdge" }
    export const longestEdge = defineComputedPartProperty(
                 function(context is Context, part is Query, definition is map) returns ValueWithUnits
           var longestEdge = evaluateQuery(context, qLargest(qOwnedByBody(part, EntityType.EDGE)));
           return evLength(context, {
                   "entities" : longestEdge[0]
  • Jacob_CorderJacob_Corder Member Posts: 137 PRO
    annotation { "Feature Type Name" : "Longest Edge" }
    export const longestEdge = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
             annotation { "Name" : "Allow Wire Bodies","UIHint":UIHint.REMEMBER_PREVIOUS_VALUE }
             definition.allowWireBodyEdges is boolean;
            var attributeName = "longestEdge";//set this to whatever name you want
            var edgeQuery=qEverything(EntityType.EDGE) ;
            if(!definition.allowWireBodyEdges) edgeQuery =  qSubtraction(edgeQuery,qEdgeTopologyFilter(edgeQuery, EdgeTopology.WIRE));
            edgeQuery = qUnion(evaluateQuery(context, qLargest(edgeQuery)));//this executes the longest portion which is qLargest and wraps it in qUnion so evaluation does not happen again.
            setAttribute(context, {
                    "entities" : edgeQuery,
                    "name" : attributeName,
                    "attribute" : {}
            //Then later call qHasAttribute to get the edge in the table
            var attributedEdge = qHasAttribute(attributeName);
            addDebugEntities(context, attributedEdge, DebugColor.GREEN);
    that should do it
    Thanks for your answer, but this does not give me computed properties in the custom table.
    The example with the volume looks like this:
            return evVolume(context, { "entities" : part });
    How can I use this as a computed property?
  • Caden_ArmstrongCaden_Armstrong Member Posts: 290 PRO
    @elias_bonauer
    Jacob wrote a feature to find the longest edge.
    For a computed property, the query for part is given already so the code is a bit shorter:
           var longestEdge = qLargest(qOwnedByBody(part, EntityType.EDGE));
    www.smartbenchsoftware.com --- fs.place --- Renaissance
    edited March 2024
    Hi Caden,
    this works as expected, thank you so much!
    I just realized that this gives me the sum of all longest edges, not only the length of 1 longest  :|
    Right, I forgot that qLargest can return multiples if there is a tie. You could also just do qNthElement instead of evaluating.
