How can I use FeatureScript to get the longest edge of a part as a computed property
I try to create a feature script that lets me get the longest edge of a part as a computed property in a user defined table.
So far I had no success other than get the compuedVolume as shown in an example somewhere.
Can yomebody give me a hint or an example how to get all edges, find the logest and rturn that as a computed propery?
Any help is highly appreciated!
elias_bonauer Member Posts: 4 ✭✭
Ok, i figured it out, I needed to use evaluateQuery and then return the value at index 0annotation { "Property Function Name" : "longestEdge" }
export const longestEdge = defineComputedPartProperty(
function(context is Context, part is Query, definition is map) returns ValueWithUnits
var longestEdge = evaluateQuery(context, qLargest(qOwnedByBody(part, EntityType.EDGE)));
return evLength(context, {
"entities" : longestEdge[0]
return evVolume(context, { "entities" : part });
Jacob wrote a feature to find the longest edge.
For a computed property, the query for part is given already so the code is a bit shorter:
