Change / Remove Breakout View
shawnrwshawnrw Member Posts: 50 PRO
Hello,
Searched for a bit and couldn't find anything. Is it possible to remove/change a breakout view in a drawing?
Thanks
  • Daniel_KaneDaniel_Kane Member, Onshape Employees Posts: 23
    After creating your broken-out section view, you are able to edit the properties by right-clicking on the view and selecting "Edit section...". This is shown in the GIF below
    Let me know if you have further questions.
  • kevin_thorpkevin_thorp Member Posts: 9 EDU
    How do you remove a broken out section?
  • eric_pestyeric_pesty Member Posts: 2,104 PRO
    In the Gif above, just below "edit section" you can see a "remove section"...
  • troy_altontroy_alton Member Posts: 6
    Has this capability been removed or moved? I have no option to "Edit Section" in my menu.
  • bill_schnoebelenbill_schnoebelen OS Professional, Developers, User Group Leader, csevp Posts: 124 PRO
    Edit Section is no longer a option
    So……..How do we remove/change a breakout view in a drawing?
  • rick_randallrick_randall Member Posts: 389 ✭✭✭
    Just tried it - both "edit section" & "remove section" are there and working just fine, for broken out view.
