Improvement request: Linking local variables to global variable studios
Joe_Young101
Member Posts: 3 ✭✭
Would like to request functionality for
1. Angle as measured variable
2. Using variables from a part studio in a variable studio.
I need to be able to measure the angle between lines in a sketch and assign that as a variable in the part studio. I then need to be able to use that variable as a value in a variable part studio.
Using the current tools is a huge time sync in order to manage / export data. When a change is made to the sketch, I would like it to update the value in the variable part studio, and export that table for use with simulation, analysis, and tracking range of motion changes between versions.
