Can't figure out how to taper these corners inward (can't get chamfer or filet to work)
StillMaker
Member Posts: 26 EDU
I'm trying to get make it so that these for corners are not hanging off the circle base. I think an easy way to do that would be to taper them inward. I think I would usually use a filet or chamfer to do this, but it's not working. Can someone point me in the right direction? I'm guessing it's going to involve backing up a few steps.
I am going to 3D print this so need to avoid overhangs. Thanks.
Here is my document: https://cad.onshape.com/documents/8f58f91279f38a0d654f2801/w/8e73e3976c5cb4962ff7d3e9/e/05d6916ff185566ba454c379
