Using the Transform Function in FeatureSctipt
mario_acosta255
Member Posts: 9 EDU
Is there a way to use FeatureScript where you can select and Sketch and then have a function that transforms it bigger or smaller? Can you please provide me with a sample function or a similar solution provided in another forum?
Thank you in advance.
All you need to do is use opTransform with a scaling transform in order to scale a sketch.
You will need to decide how to scale the sketch, ie about a point, uniformly vs non-uniformly etc.
Here is a sample:
https://cad.onshape.com/documents/44250afbeb494efd33079dfc/w/9fd1d6964469168e13e5a13a/e/141efda7344902ed80fe5238
This is what I am looking for right now
Thank you for this sample!
