Assembly - linear pattern with angle
In an assembly, I am trying to do an angles pattern of tiles, but can only find to do this in X, Y and Z. Is there a way tp pattern under an angle or along a line?
GWS50 Member Posts: 455 PRO
Try using a mate connector to specify the direction.
https://cad.onshape.com/documents/bbc018b5d5ce0b60493ff972/w/374018992412a696e41b541e/e/e9aafe5efa5c4669730e138b
