Is there any way to search for objects that have degrees of freedom?
Member Posts: 326 EDU
I see the DOF icon sometimes, but if it's at the top of an assembly, there doesn't seem to be a way of quickly showing you the actual parts inside it that have some DOF.  Is there a way to filter or search for them?
  • Member Posts: 144 PRO
    @STEG while there is the visual indication of the icons for DOF, there does not appear to be a way to filter by parts that have DOF in the same way that you can use special commands like :errors or :part. This would be really useful if it applied to subassemblies as well.
