create funnel with uneven distance to the edge
VoyagerVoyager Member Posts: 19 EDU
Hey, I would to create a funnel like thing, where the rectangle in the middle is the hole.
Since the distance isnt equal, sweep isnt working as I would like it to.
Can someone please suggest me a efficent way?
Thanks!
  • john_lopez363john_lopez363 Member Posts: 140 ✭✭✭
    @Voyager
    So the depth of the Thicken (3mm) is causing an intersecting region error.  One way to solve this is to change the shape of the smaller Loft profile (I changed it to a slot vs a rectangle with corner filets).  While this allows a 3mm thick Loft it does leave a bit of odd geometry on the inside of the part.
