A loft between two surfaces doesn't seem to create a solid - it can't be 'shelled'?
frank_paynterfrank_paynter Member Posts: 25
I created a loft between a 3x4mm rectangular sketch and a circle 40mm away. Now I want to hollow out the resulting solid (actually I want the surface of the loft to be the inside, with 2-3mm solid outside).  However, I can't seem to use the 'shell' or 'extrude' tools to do this - it seems the loft shape isn't a solid - what have I done wrong here?
TIA,
Frank
