My loft isn't symmetrical, the sketches are aligned, how can I make it symetrical?
fabian_reisfabian_reis Member Posts: 9
the question says most of it, here are a couple of screen shots and I tried to add a link, I hope it works
https://cad.onshape.com/documents/5aaf431ada3e0a7ac97c214a/w/946b3344414104845f887f2d/e/5cbc9bace42fbf425f6ed504
  • glen_dewsburyglen_dewsbury Member Posts: 1,295 PRO
    edited March 2024 Answer ✓
    Defining connections will set the orientation to make the transition uniform with out the twist. Note, the the simple construction line in bottom sketch to provide a connection point.
  • fabian_reisfabian_reis Member Posts: 9
    thanks so much!
