Issue: Sketch > Pattern tools only propagating some of the selected geometry
karl_mochel
Member Posts: 56 ✭✭
The selection...
The Linear Array tool is only propagating the top line, and there is no alert/message - Expect something like "Cannot work on all of the selected entities because..." so that I know how to fix the problem.
https://cad.onshape.com/documents/a84e4a5ca67dab8f05226f87/w/da2e02b1cfc363b6ee32f4f9/e/6c7d201699756e39298e6128?renderMode=0&uiState=65f77088dd73006b5a13900f
In this case, I agree with Nick, patterning a part is probably the most robust solution.
What is the end goal shape you’re trying to achieve?
2) See previous post - a wavy disk.
3) Yes.
4) OK... Figuring out one different then I thought up is the problem...
https://cad.onshape.com/documents/42789d61df0e6a7371d630f1/w/5bd04f8e1638ae8f16c1c293/e/a91ee328db610276a462c51a
