Circular Transition
martin_kopplow
Member Posts: 293 PRO
I have a seemingly simple problem. I want to create a smooth transition between the 2 slabs. It is to be tangential at the start and end profiles, and that is easy so far. But I also want it to be circular in the plan form. Now, I could play with the start and end magnitude of the loft, until I get pretty close, but this provides little control, modifies the slope at the same time, and then I'd like a precise method, one I could reproduce exactly each time, and possibly also make configurable later.
Any ideas (except for replace face, which does neither work nor is it precise) for this simple one?
One way would be to draw guides on the left and right side via sketches, then project them to the cylindrical surface. Then loft the two guides together, or use them as guides for the one solid loft.
https://cad.onshape.com/documents/45f3e544fd918a950b6489e6/w/cb2f77229993baa59e9daf2b/e/f276d2...
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
the surfacing option would be to loft or boundary surface the top and bottom faces, and then mutual trim the sides.
like so:
https://cad.onshape.com/documents/8f0dc9c64a802eb2b3e126ef/w/c2fdf4bed38e57c3c96ed60e/e/e9300ab1942186f21e656232?renderMode=0&uiState=65f327cdc1b8263c21e0bfe0
the tangency_magnitude parameter can be used to manipulate the smoothness for all 4 transitions in one go.
so in terms of smoothness i think it probably may match your expectations.
I'm not sure this would work robustly in a configurable setup though. the 'move boundary' is rather ugly and also mutual trim directions may flip and cause errors.
kind regards
Jelte
You could create 4 Bridging curves (with Match tangent option) between the corners and then use 4 Boundary surfaces (with Boundary condition set to Match tangent for V profiles). Note that all dimensions are random for my 2 slabs.
Like this:
https://cad.onshape.com/documents/5cb32d69b83de94b79486e00/w/bd9cfbd6a34092b4703880fd/e/f777f6752915e445a0f46523?renderMode=0&uiState=65f443a808dd463894cdc15f
https://cad.onshape.com/documents/5cb32d69b83de94b79486e00/w/bd9cfbd6a34092b4703880fd/e/fc281499b0e98d03c567d1a2
https://cad.onshape.com/documents/3af4454171b98709f4c7eb7a/w/717b3fdedf1ada614af0091f/e/cf1aa36c605692c00bf47bce
Ah, the wrap is a great idea. This will give you exact control. Since it is a simple 90 and a cylinder, this should work fine.
This is NOT some type of FOOT PATH. Right ?
Lol, this is going to be one legit sidewalk transition! I want each of our user names etched into this when you finish.
@martin_kopplow, the wrap approach can be achieved by measuring the length of the inner and outer radius, then constraining the heights of the wrapped sketch splines horizontally to the vertices of their end locations.
Here is an example of precision wrapping:
https://cad.onshape.com/documents/45f3e544fd918a950b6489e6/w/cb2f77229993baa59e9daf2b/e/892acec2dec20d87e0ff2...
For what it’s worth - for any interested in pedestrian ramp design, here is a good starting point.
https://www.ada.gov/law-and-regs/design-standards/
But I do like all the G1, G2?, and G3? continuity. Wonderful stuff.
Yeah, those government people do like to get wordy that is for sure.
Here’s one with a bunch of illustrations
https://www.access-board.gov/files/ada/guides/ramps.pdf
