Why is my mate assembly overdefined?
sylvan_blakesylvan_blake Member Posts: 2 EDU
My mate assembly is overdefined. I'm pretty sure all of my measurements are correct and I'm using fastened mates. My problem occurs when establishing the second mate between the under arm cushion and the side support and the second mate between the handle and the side support. I have also tried slider mates but I get the same problem. Thank you.
https://cad.onshape.com/documents/806a70347326d9f6bb51727f/w/2adfaf81e763939fc7de6edb/e/96e003633d280eeaa7218674?renderMode=0&uiState=65f9c3454ca40d549131cd0d
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 945 PRO
    edited March 2024 Answer ✓
    Onshape only requires one to constrain a part.  A Fastened mate fully constrains all 6 degrees of freedom of a part.  In your assembly:
    Part 1 <1> is fixed
    Fastened 1 fixes Part 1 < 3>
    Fastened 2 fixes Part 2 <1>
    Fastened 3 fixes Part 1 <2>
    Fastened 4 fixes Part 1 <4>
    Any more mates will overdefine your assembly.
    Part 1 <1> is fixed
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 385 image
    Each (rigid) body has 6 degrees of freedom. One fasten mate constrains 6 DOF…
    You have 6 bodies, and one is  already “fixed” so you need to constrain 5x6 DOF. Therefore 5 fastens will fully constrain it.
    If you suppress Fasten 2 and Fasten 4 all will be good on your model. And since you used one slider this leaves one DOF free to drag.
