Please allow non-rigid sub assemblies to be added to groups
david_brophy
Member Posts: 53 ✭✭
It would be great if non rigid sub-assemblies could be added to groups.
Consider this document:
https://cad.onshape.com/documents/b309c378912a7dde8ca3a025/w/aaae5126aef52abcabdcb202/e/dceb7664bda32e85e95978fa?renderMode=0&uiState=65fdd012362fd31ffcd47663
Inside "Hinged assembly", the two parts are connected with a revolute mate. I would like to add "Ground" and "Base" to a group, however I get the error below:
@david_brophy why do you want to use a Group instead of using a Mate bertween the base and the ground? 🤔
Here's a section view of how the windows attach to the wall... I hope you can see that using a mate to attach it to some vertex on the wall wouldn't be ideal... Both the rebate in the wall and the location of the window are defined by the master sketch, so that's how I'd like to position the window in the assembly...
-Get rid of all "fix" mates. IMO, fix should be removed from the program.
-Make an explicit MC as the first feature in each asm. Use that MC when mating lower level subs to higher level subs. In your scenario of a master sketch in the top level asm, you can mate the MC of the lower sub to the sketch itself.
-Get the featurescript multimateconnector. You can use this for super reliable placement of "modeled in place" parts within an assembly. This will create a MC for each part in your part studio, that you then mate with the explicit MC made in the asm in the prior step.
-There is a new functionally as of a few weeks ago that may be useful to you, where an entire part studio can be inserted into as asm as a fully constrained and rigid group of parts. They update automatically as you add/delete parts from the part studio. It's all or nothing, however, on which parts go to the asm.
