How do you create a Clearance and Tapped Hole whit the new update?
I used to be able to do clearance and tapped holes pretty easy using the 'Blind in last" option
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,471 PRO
    Change the "fastener fit" value in the tapped hole from "none", definitely not the most intuitive...
  • Carlos_BorraezCarlos_Borraez Member Posts: 4
    For some reason, I do not get the Free hastener fit.
    It looks like it works when doing a simple hole but not a countersink or a counterbore
    Any ideas?
    Any ideas?
    Fastener fit is just below the "Class" (5H)
  • Michael_BillsMichael_Bills Member Posts: 29 PRO
    I am also having this issue. I can make a multibody clearance and tap hole stack in "simple", but not in countersink or counterbore.
