pasted sketches not being able to placed and moved to another sketch ?
So I'm new to Onshape and I'm still learning, but I'm having issues with a selected sketch when I go to paste it on another sketch plane it doesn't appear there it only appears above not where it is intended to be I want it to be placed 2 sketches lower can someone help.
  • S1monS1mon Member Posts: 4,040 PRO
    edited March 2024
    Paste doesn't remember the previous location. When you copy and paste (or import) it ends up in kinda a random location. It's really pretty annoying. You can use the sketch transform tool to move something into place. In this case I'm not really sure what you're trying to do, since you can easily "use edge" if you want the sketch in the same place as it was in a previous sketch.
