Countersunk holes
henry_methorst
Member Posts: 4 ✭
Hello,
When I go to add a preconfigured countersunk drill hole, the drill size changes when I select, say, #48 (0.076) vs any other, but the countersink diameter doesn't change at all no matter what size drill hole I select. Is this normal?
It you change the hole type from "Drilled" to "Clearance" then the countersink will adjust to the selected fasteners size.
