replace multiple faces with multiple faces.
robert_stilesrobert_stiles Member Posts: 129 PRO
Are there any replace to multiple faces custom features, or extend to a container type thing? Think of a spiral stair, rising inside a square tower, and the treads and risers need to extend to the extents of the bounding walls. I have had this type of problem a couple of times in a range of situations, and resorted to oversizing and Boolean>remove, or over sizing and splitting parts and removing one side.  But when the design is parametric, and parts are added or fall in differnt positions, this falls over.
I'm sure I'm missing a simple trick.... maybe a tool I don't use much, like replace face, only more powerful.
Thanks
  • S1monS1mon Member Posts: 3,455 PRO
    Despite the dialog asking for a "Surface to replace with", you can only select a single face. This is indeed annoying.
    Here are some improvement requests:
    https://forum.onshape.com/discussion/11061/replace-face-with-multiple-template-faces
    related:
    https://forum.onshape.com/discussion/20249/replace-face-keep-tools-option
    You can extrude up to a part, which can be a surface (as in something with multiple faces), but unlike replace face, it won't extend the surface if it doesn't quite cover the extrude.
    Splitting a part with a surface is probably your best bet, or boolean subtract with a solid part.
    Maybe you can share a public example document of something that you're trying to do and I'm sure there will be a bunch of different solutions.
  • robert_stilesrobert_stiles Member Posts: 129 PRO
    Thanks, one I had already voted up!
  • ry_gbry_gb Member, csevp, pcbaevp Posts: 34 PRO
    Just ran into this problem this past week. It's less than ideal to have to find workarounds for this.
