Fillet tool - missing functionality.
joepjoep Member, csevp Posts: 25 PRO
It appears the fillet tool is missing functionality.
    jnewth_onshapejnewth_onshape Member, Onshape Employees Posts: 67
    Change "Measurement" type to "Radius". Under the hood these operations are quite different, so we customize the UI on the fly to match. For example a constant width blend is implemented as a face blend, while using the blend radius allows for an edge blend, with many more controls.
    @jnewth_onshape , Thanks for clarifying.
