Can i change the shape of a circle but keep the same circumference
john_mcnicholl
Member Posts: 4 ✭
I am trying to print some tyres for my bandsaw they have a 300mm dia. My printer bed is 250mm x 250mm .
i am printing in TPU95 so for my application i dont need to print it as a circle as it is effectively a rubber band
i know there is a simple salutation to this issue thanks
In theory, it would be possible to create a wavy shape which would have the same path length as a true circle and fit in the bed. I suspect they might be kinda weird once you stretch them to be round again. You could also split the tire into two half circles with some tabs that interlock on each end.
First off, I tend to agree with the previous comments. This may not perform as you expect.
That said, I do not know of a feature that will take a circle and fold it while maintaining the circumference dimension. You can "hack" this by creating a closed spline and then using the measure tool to determine the length of that spline. Adjust the spline until the length is what you need. The circumference of a 300mm circle is 942.47mm. Here's an example.
Once you have this then do an Extrude Thin to the final size you want.
There is a place in the states that will make them to order but the cost is prohibitive once again thanks for all your help
