What excatly "cap void". How does it works?
Narayan_K
Member Posts: 379 ✭✭✭
Hi,
When i working on Onshape i found option "Cap void" in delete face.I was in curious to know what it is? and went thorough help in"?" button and found below result
As said above If we uncheck the Cap void it extends surrounding faces until they intersect. it works fine.If i check "Cap void", delete operation performs without deleting faces.So i didn't understand the word highlighted in above image.
Can any one help me to understand that?
andrew_troup
Member, Mentor Posts: 1,585 ✭✭✭✭✭
There's a good video which deals with this
If you go to https://www.onshape.com/learn/on-demand-training#!training-recordings
and choose "Direct Editing Training", and run forward to 9m45, you will see this explained5
We still have the 'Delete face' feature:
https://cad.onshape.com/help/Content/deleteface.htm
If you can't find its icon, it might be hiding in a dropdown behind another feature in its group; look for a small downward facing arrow next to one of these icons:
Additionally, the 'Cap void' functionality is now accessed by the 'Cap' option in the dropdown.
