Fix Broken Mates option and dialog
When in a large assembly, it can be difficult to manually scroll through hundreds of mates to find the broken ones. It would be great to be able to right click on "Mate Features" and select a "Fix Broken Mates" option that can bring you to each broken mate, highlight the previously involved parts (if possible), and then move on to the next broken mate after solving or skipping the current one.
Additionally, it could be very helpful to have a small window showing what the previously mated features were, either with an isolated instance of each previously referenced part and mate or with a navigate-able preview of the previous unbroken mate.
  • eric_pestyeric_pesty Member Posts: 2,276 PRO
    You can use the filter with :errors to filter the tree to only show errors.
    If you also have a bunch of other errors that aren't mate you can combine filters ":mate :errors"
  • Michael_DiPretaMichael_DiPreta Member Posts: 8
    I somehow missed the "errors" filter, thank you!
