How to insert nut onto bolt?
Greetings!
Last year we had the same problem with the countersink bolt and the SHIFT trick worked wonders this year! Thank you.
However, new problem....we can NOT get the nut to attach. Is there a new "trick" to get this to work? Is there a way to select the bolt first and then the nut like a fastener mate?
Please Help!
Jen Kuhowski
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 930 PRO
    The confusion might be coming from the fact that you want to attach the nut to the face of whatever flat part the nut will snug up against, not the bolt.
