double curved surface fill
znerol_1
Member Posts: 8 ✭
Hi everybody,
total onshape beginner, i have had a look at several post regarding the creation of curved survaces but could not find a solution:
I want to create a surface so that the part could be mirrored on each axis without creating any ridges. On each corner the edges meet at 90 degree angles.
Any hint much appreciated.
Cheers,
Loz
Cheers,
Loz
glen_dewsbury
Member Posts: 1,289 PRO
Here is a sample using a loft. Tangency is maintained at the sketch level and loft(normal to profile). Can be a surface or solid. Won't make any difference. Set to display without edges for a clean look.
https://cad.onshape.com/documents/876cd7da860d4c14b3b81810/w/8c4e8033cb786c26786d4e0c/e/390eb47b31c21f33bc6077bf
I managed to solve the issue, I believe my sketches were wrong, as mentioned by by Glen. I created the curves with splines at first that did not actually produce 90 degree angles on the corners. So, after i remade the curves as bezier and ensured that the corners meet at 90 degree the tangency worked
