angled bottom
morten_skerra
Member Posts: 4 ✭
I am making a tub, this tub should have a bottom that is higher at one end than the other
so that the water will flow from the high end to the low end where there is an exit.
how is this done.
how is this done.
Seen from above, this tub has rounded corners with a diameter of 30 which does not
make it easier for me to understand
