Reset material so featurescript can modify it?
david_brophydavid_brophy Member Posts: 53 ✭✭
I have a lot of bodies which have had their material properties edited interactively. I've now created a featurescript to change the material properties with setProperty. However this doesn't work for bodies where the property has been changed interactively, even if the material is reset to "None". Is there any way to force featurescript to take precedence? Or reset the body so it can be affected by featurescript again?
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 863 PRO
    Have you tried the "Reset all" button in part properties?
  • david_brophydavid_brophy Member Posts: 53 ✭✭
    That worked a treat, thanks! 🙏
