Cut List Equations
Craig_Sinclair
Member, csevp Posts: 7 PRO
Can you add a simple equation into a cut list part? I'm looking at editing the cutlist and using the column overide to add a simple equation on certain frame parts. Example Length-5mm. With our frames they have alot of mitred corners and our manufacturing team need Inside length not overall in some instances as the cut length. Is this possible?
I've made a few custom features for one of our clients who needed to be able to override the frame lengths and cut directions. This would involve having a few custom features: "Override frame", and a new modified "Cut list" feature that can handle the overrides.
Let me know if your interested, I can set up a discovery call for you.
cadsharp.com
RENDERCAD
RENDERCAD
