desmodromic valves
joe_malle015
Member Posts: 4 ✭
Hi - I'm an onshape beginner. I'm trying to model desmodromic valves from https://en.wikipedia.org/wiki/Desmodromic_valve
I have https://cad.onshape.com/documents/bf37568cc295f8da5ab4f41a/w/84bd7e4d3b3520dbb9c8db8b/e/7931a0488897a8f8fe78d87e so far.
As you can see, the part of the cam that controls when the valve closes is wrong. I did this part of the cam pseudo-freehand to approximate what I'm trying to create. Ideally this part of the cam would be tangent to the orange lever part (named "desmo").
Is it possible for onshape to deduce the shape that this piece must have so that a tangent mate between the face of the cam and the "desmo" lever would work?
P.S. I have some programming experience, so I don't mind if the answer requires scripting.
https://cad.onshape.com/documents/075755f3a5af3b131044db83/w/1831ce24396a3690795010a3/e/a91b0a601fac142884f40996
ANYWAY... thought I'd play around a bit and came up with this!
I'm pretty satisfied with this result, although there is still a small overlap between the new "desmo" lever and the cam at some angles. Any advice on how to rectify that?
