Comparison Two Features/Parts/Surfaces in the Same Version
Member Posts: 9
Hello,
Is there somebody knows how to compare two surfaces that I created in different ways? I need a tool to show the deviation between the surfaces. Since they are in the same version I can't use the in-house comparison tool of OnShape.
Thanks in advance.
  • Member, Onshape Employees, csevp Posts: 86
    edited April 2024
    If I understand this correctly, you could just branch of the version and then compare the branched workspace with the initial version.
    Principal Technical Services Engineer, EMEAI
  • Onshape Employees Posts: 726
    Add an empty part studio, branch, derive surface1 into this part studio in one branch, surface 2 in another - now you can use compare tools
