API call that includes info on if a part is sheet metal or not
in General
I have tried using the body details end point and metadata but I am not seeing anything in those that I can use to definitively gate a yes or no if it is sheet metal. Anyone know if there is a way to do this without relying on putting information into part properties?
Caden_Armstrong Member Posts: 230 PRO
You can do it with the /parts/d/{did}/{wvm}/wvmid} endpoint with the url param for includeFlatParts=true
Flat parts will be "isFlattenedBody" set to true.
They will also have a property "unflattenedPartId" which corresponds to the part id for the folded part.www.smartbenchsoftware.com --- fs.place --- Renaissance
Custom FeatureScript and Onshape Integrated Applications1
/partstudios/d/{did}/{wvm}/{wvmid}/e/{eid}/featurescript
and in the FS evaluate qActiveSheetMetalFilter with the parts in question.
Ah yes. Thanks. That will give enough info for a solid if statment.
