Part/Body Type Property
pharesphares Member Posts: 15 PRO
Forgive my ignorance, this is the first time I have played with featurescript.
Essentially, this is what I am trying to do:
if bodyType = sheetMetal then setProperty description "sheet metal"
From reading the documentation I was able to set the description but I cannot figure out how to filter only sheet metal parts.
OnShape seems to know if a part is sheet metal or not, I just need to know where that property is stored. Is there something like BodyType but for Sheet Metal, Frames, etc?
  • pharesphares Member Posts: 15 PRO
    Thanks to Alex's FeatureScript Examples I was able to figure this out using ActiveSheetMetal.YES
    I would also like to set the VENDOR property but it doesn't seem to work. Please take a look, I would love some criticism of my code.
  • Caden_ArmstrongCaden_Armstrong Member Posts: 413 PRO
    Just note that ActiveSheetMetal will only work for active models. Once the finish sheet metal feature is added to the tree, it will no longer work.
    Another way to check is seeing if there is a flat pattern for the body.
    isQueryEmpty(context, qCorrespondingInFlat(mySheetMetalBody))
