Garbled characters when Edit dimensions in Drawing
alex_vestasalex_vestas Member Posts: 68 ✭✭
what means garbled characters when Edit dimensions in Drawing? Also missing "✖" close icon.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 6,022 image
    That just indicates where to grab it if you want to move it out of the way. Click out to close the dialog.
  • alex_vestasalex_vestas Member Posts: 68 ✭✭
    Also, why "show/hide units" icon is missing on some drawings? It is very inconvenient, plus  there is no sense to hide measurement units at all.
    Engineering drawings typically have the default units stated in the title block so there is no unnecessary repetition. The show/hide units only displays if you set a dimension's units to be different than the drawing default.
