How to select the required dimension for hole?
alex_vestasalex_vestas Member Posts: 68
I've created a hole, but unable to set the required dimension = 6.45 mm, no such "Drill size" in selector.
How to solve this?
  • rafael_telgmannrafael_telgmann Member Posts: 137 ✭✭✭
    Just type your dimension here... it will overwrite the Drill size.
  • alex_vestasalex_vestas Member Posts: 68
    Strange. I already tried this and it didn't work: the hole dialog complained about size mismatch (Drill size ⌀ 6.4 is less  than hole size 6.45) and wouldn't let me apply the settings. But this time it worked. Maybe Onshape bug.
