How to select the required dimension for hole?
I've created a hole, but unable to set the required dimension = 6.45 mm, no such "Drill size" in selector.
rafael_telgmann Member Posts: 137 ✭✭✭
Just type your dimension here... it will overwrite the Drill size.0
