Export or Collect the Coordinates of Points on a Sketch
Hello,
I have few points on a sketch. I need to export the coordinates of these points in any format, csv, txt or collecting manually from a pop up message box. I need to have a automated script for this process because I will have a hundred of these points. Does anyone know how to do it?
https://cad.onshape.com/documents/ce3ffb7bcb1ad02727fd8f8a/v/fca607809a625ff979a5ff6c/e/4754bcbcfaef84b11e307910?renderMode=0&uiState=66311219f6b4b1085fbfdc56
There's an alternative version in the same doc that extracts the control points of the spline (or spline approximation) and writes the x,y,z to a custom table. The bridging curve shown below is G2/G2 hence the 6 control points as seen in the table.
