Hide the detail view external circle
florianflorian Member, OS Professional Posts: 110 ✭✭✭
Is there a way to hide the circle surrounding a detail view (1) in a drawing? You can set the color of the parent circle (2) to almost completely white (#FFFFFE) under (3) but there is no feature to get rid of (1)?
This is what I would like:
  • romeograhamromeograham Member, csevp Posts: 712 PRO
    @florian setting the color to reduce the visibility is a clever workaround trick!
  • florianflorian Member, OS Professional Posts: 110 ✭✭✭
    @romeograham but that trick works only on the left circle where you don't need it. The second drawing is manually edited.
    There is another workaround that is not parametric:
    1. Draw a detail circle
    2. Move the view off to the side off the DRW
    3. Insert a new view and crop it to what you need
    4. Move the detail label to your new cropped view
  • andrew_brady909andrew_brady909 Member Posts: 1
    This should be a show/hide option in the detail view itself, but it's not there. This "border" in the detail view can be very confusing and or cause clutter especially when you're not using a circular detail profile. OnShape team?
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 554
    @andrew_brady909 Detail view style controls are something we have on our radar to improve.  Not many controls on this at the moment other than what has been mentioned already here.
  • Jack_BrentanoJack_Brentano Member Posts: 11
    Is there any update on this? It's inconvenient to have to insert additional views off to the side of the drawing every time you do a detail view and want to remove that outline.
  • mario_rauchfußmario_rauchfuß Member Posts: 10
    I have the same question.
    I hope that a useful solution will come soon.
    M
    Changing the color for compasses no longer seems to have any effect on the color of the compass around the detail display.
