Issue with profile generator v46 - missing point in the leading edge make loft guide fails
Hello,
I am desiging a wing with the E205 profile. The generated spline doe not have a point exactly on the leading edge where I have the shape of my wing drawn:
A picture: so if I use a loft guide with my wing shape - it fails. Any work around ? when I look at the code of the profile generator, there is a special case for the profile not having a 0 coordinate. But does not seems to do the job here ?
